Discuss what do i need to install slatted spring waste for sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Hi there - I have just bought a suspended sink unit which only came with the sink, the unit it fits into and the slatted spring waste. What I need to know is what items I should buy to complete installation, especially for the slatted spring waste, as I can't understand what I can buy to cover the two holes I hope you can understand this, as I have visited loads of diy places and can't seem to get an answer as they don't seem to know what I am talking about. An early response would be greatly appreciated, as my husband is just about ready to throw it into a skip. many thanks.
What is the problem with the Slotted waste fitting ? is it the pop up type, the other thing you will need is the taps, if your unsure how to install this item, then it would be better to get a plumber to fit it ! save any damage or unnecessary expense
If your basin has a built in overflow, you will need the slotted waste
Also you'll need to register with the forum as per rules
as said please register with us to get more answers to your questions
Reply to what do i need to install slatted spring waste for sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with...
Hello We recently had a bathroom referb with a new sink and vanity unit that contained all new plumbing for it. The sink doesn't have an overflow...
A while ago I replaced a leaky, corroded sink trap. That all appears to be fine, I can't find any leaks with it, and everything under the sink...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
Hi Guys, My chimney failed the test so I need to install a flue liner for my Gazco Stockton gas fire. It was over a year ago when the engineer...
