Discuss Wet room question regarding best pump to use in the USA area at PlumbersForums.net
Can anyone recommend a decent wet room waste pump as the one fitted keeps blowing fuses and needing resetting. It is in a retirement home so needs to be reliable. I don't need the waste fitting, just the pump which is in a cupboard behind the shower room. The pump is activated by a flow switch. Thanks
Have a look at akw how old is the existing unit ?
I had it reconditioned three years ago as it was playing up but it started to do it again.
I have now ordered a Whale pump now as I needed to get it done quickly. Hopefully it's a decent pump which wasn't cheap. Thanks for your suggestion though.
Yes there good aswell you will find they make them under different names also
Fwiw, I was going to suggest a whale pump, we fit them in social housing, and they’re a good reliable pump, technical helpline is spot on as well.
Haven`t heard one working in 2-3yrs, are they any quieter than they were?
Reply to Wet room question regarding best pump to use in the USA area at PlumbersForums.net
Hello, looking for some advice with regards to our new wet room shower, we have noticed a leak in the ceiling directly below the shower. We have...
I am replacing an air source heat pump. The current hot water tank, valves etc are all staying so should be a fairly straight forwards procedure...
I live in a converted Victorian pub, and our kitchen and downstairs bathroom are at basement level. Behind the downstairs toilet there’s a...
2K
During my shower yesterday the pump stopped working. The Aqualisa Aquastream was installed approximately 10 years ago and has been very reliable...
11K
Daniel Lee
This maybe isn't so much about asking for advice as giving it 🤔 I had a leaking HW cylinder (23 years old) that I got fed up patching up with...
2K
