that could have been what happened when the engineer was trying to release the water pumpYes or you deform them trying to undo them eg oval I’ve put a video up that I managed to find
Discuss water pump issue? in the Central Heating Forum area at PlumbersForums.net
update: the source of the leak is here. i've attached some photos. i double and tripled checked the whole fitting in case there was multiple leaks. thanksIs it leaking from the pump nut or where the valve screws into ?
thanksYep drain the whole lot
Reply to water pump issue? in the Central Heating Forum area at PlumbersForums.net
