Currently reading:
Water pressure with unvented
Discuss Water pressure with unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Gerard17
Is 14 litres per minute god enough for a unvented hot water cylinder?
So........you know the flow rate. What's the pressure?
Shouldn't you already know the answer to the question if you're qualified to fit them?
You need to check with the manufacturer of the cylinder what they require. Most are about 21 litres pm
If you only want 14 L/M flow rate then it is good enough, if you need more then it isn't. To give you an idea one good shower working will draw 12 L/M leaving just 2 L/M for anything else that may be on at the same time, not a lot is it.
20 might be better for you average house but it an't going to be any good for a 3 bathroom 6 bed place. See how it works ?
What type of fitting (taps) are you going to be using what flow rate do you need for them to work correctly, as before, what pressure do you have, how high is the cylinder / fitting going to be. Just a few of the things that need to be considered, it is not so easy this old plumbing lark is it.
Reply to Water pressure with unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
