Discuss Water flow path through radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been trying unsuccessfully to find a diagram that shows the path water takes when flowing through a domestic radiator.
Anybody got any ideas?
Is it to highlight something or just interested?? It will also depend how it’s piped
nope its open in there unless its a fancy column rad
standard rad is indented to give the rad more surface area which increase the heat capacity a bit
uses natural convection currents. if you feel a rad as it heats up its starts getting hot at the flow end then gradually increases across the rad.
With a normal radiator it depends on whether both connections are at the base or one top and one opposite bottom.
Both connections at the bottom (all of mine) are slightly weird, but explainable - you tend to get convection lifting the hot water over just one side, then the top gets hot and eventually the other side gets hot in a top to bottom way until the whole thing is steady.
Try turning a cold rad on and feel which bits heat up in which order - that's an approximation of your water flow.
In the old days ....before my time the practice was to put feed on top stabbing and return lower stabbing on opposite side. Then it was discovered that convection flow allowed in and out on bottom stabbing son opposite sides, sludge builds up on bottom between in and out and results in cold spot along bottom of rad . See pics of this to determine heat flow, or point your iPad on thermal camera at a cold rad to see fir yourself
In the old days ..before my time the practice was to put feed on top stabbing and return lower stabbing on opposite side. Then it was discovered that convection flow allowed in and out on bottom stabbing son opposite sides,
Morning Rob.
Rads 'were' always designed as you say. AFAIK that still works and is the most efficient & effective piping arrangement.
The change to bottom in bottom out was led by nothing more than the technical and moral depths of 'fashion' in the late 60s. It was deemed 'ugly' to have pipes on show so, being the sheep we all are, everyone copied it and we have what we have. Where I am 'allowed', I still pipe rads top in bottom out - 'she' don't like it tho :rolleyes::rolleyes::rolleyes:
Morning Rob.
Annoyingly, the vertical rads I have in 3 rooms would have been easier with one pipe in the top - as would the towel rail as I'm on a drop system (solid ground floor). But the rads all required bottom inlets (verticals have a separator in the top bar halfway).
o_Oo_Oo_O
Reply to Water flow path through radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What do you think?
