Discuss Wanted: 3 Function SDS Drill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dmheat
Hi
Need a 3 function SDS drill (ie chisel function) ASAP.
let me know what you've got, I'm in Hertfordshire
thanks
danny
Cheap and does the job and comes with chisel bits
Titan TTB278SDS 5kg SDS+ Drill 240V | NoLinkingToThis
I want to use it with Adeys Vibraclean, will an SDS that heavy batter the radiators a little too much? Lol
it should have a variable trigger on it, so don't press it fully
It will be fine. I use my Bosch sds on hammer stop with my vibraclean
dont do it!! i have one of those, it will put the rad into the next room.lol
not only that it will kill your arms due to the weight within a couple of rads.
go for the evolution drill for £50 found on fleabay for that job.
scratch what i said....just re-read and the 5kg 1500w titan will be too much for the vibra! the bosch i use is a 650w 2kg
Be very gentle with the trigger mate otherwise even a little 18v combi drill with hammer stop function would be ample
It doesn't have variable trigger but has speed adjustment 1-6 on the wheel on the side. Will be ok just whacking it on 1 or 2 and not putting much weight behind it?
Reply to Wanted: 3 Function SDS Drill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hello! while saving up for a new plumbing and heating installation for my new one bedroom flat, i did a lot of research on different boilers and...
4K
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
1K
Hi.. I am after advice on installing a bidet in a toilet with the water valve hidden inside the cistern. I am renting. Is there anyone with a...
hi all i need some help and advice i am tiling around 2 shower pipe fittings. as the measurements were intricate i was practicing on off cuts...
1K
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
