Discuss Vokera linea 28 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mark8476
Hi guys I've a vokera linea 28 hot water side is fine it's the heating side I've a question about when boiler has reached its set target heat say 75 boiler starts to cycle of on now them temp does drop quick down to 58 then boiler fires back up again an repeats this so is it suppose to drop that quick even tho it been on a while rads are set at 3 also noticed pump to be hot to touch hotter than flow pipe cheers mark
ok I was just trying to compare with my partner dads boiler his is the linea 24 same amount of rad an set at 3 but his cycle time last longer it gets to 75 nocks off an seems to to take a while till it get to about 62 then fires back up
Reply to Vokera linea 28 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
B
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank...
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads...
Good morning, wondered if anyone can advise please on a resolution? My set up at home is that I have a 4-bed detached with 21 radiators...
5K
Morning and thanks for letting me join the group. I'm having a problem with my Intergas 28/24 boiler. The boiler will fire up first time ...
Deleted member 120897
