Discuss vokera linea 25 he ignition problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Hanns21
hi, problem with vokera linea 25he, spark transformer had failed. new one installed and now when trying to ignite 9/10 times it fails and fault code 10 (ignition failure). when it does ignite theres a quiet banging noise from flame as I its lacking gas and then it runs fine until it trys to ignite again. when working the inlet working pressure is fine. In test mode I have set the high and low co2 settings but its not helping. any ideas please?? thanks
Hi mate. The forum does not give advise on gas related questions to non gas safe registered engineers. If you are gas safe registered then follow the forum rules regarding joining the gas safe only forum and then ask your questions there.
Welcome me to the forum.
I am gas safe tho you need ten post to get into has forum which is hard for newbies to the site!
Yes im gas safe registered, i thought there was enough information in my question to suggest otherwise
it is not difficult to get to ten posts you are on three already. just go to the new members introduction section and welcome a few you'll get to ten in a few minutes.
Reply to vokera linea 25 he ignition problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
