Discuss Vaillant F25 error code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
manumadness
Hi, Im working on a Vaillant and the F25 code is showing after looking in the manual its saying theres a fault with the Vaillant compact thermal module cable harness. Can anybody tell me hoe to replace this.
Thanks:speechless:
Do you know what F25 is referring too? Have a multimeter? GSR? :)
Need more information on boiler Model // as lots of vaillant boilers. :bulb2:
Reply to Vaillant F25 error code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
