buckley plumb
been asked to fit a vaillant plus - what are the vaillant controls like now are they easier to use than the older ones - the customer is old but requesting the vaillant rf programmable control
Discuss vaillant controls in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If they are above retirement age i would stick with a basic up and down stat. The vaillant programmable stat is still a bit complicated for some people. You dont want endless call backs when they realise that they havent programmed it to call for heat.
This is good advice. Vaillant controls and simple, do not go together. However, I can understand the ease of the installation side with plug-in stuff that come with most boilers now.
If you are a bit more confident with your wiring, this one is ok:
Siemens RDH10-RF Wireless Digital Room Thermostat: Heating Controls Online
Fitted one a few weeks ago and elderly customers could understand it and work it. It is not programmable, so a basic timer was already fitted to the boiler which I left on timed - The stat has both existing room temperature and setting temperature on display.
The reciever device on this had a nice footprint which allowed wiring up the back easily and it set itself up by just removing the battery slip on the transmitter device.
For the price as well which was just over ÂŁ50 from plumbase, was not so bad.
Reply to vaillant controls in the Plumbing Jobs | The Job-board area at PlumbersForums.net
