U
Unregistered
I am working with a contractor who has installed a cistern with auto siphon to flush 3 urinals.
The urinal flush drips constantly but never flushes.
The cistern is not located above the centre of the urinals, but on a side wall. As the flush pipe leaves the cistern it turns 90 and runs around the corner to the centre of the 3 urinals then splits off to the individual urinals.
The cistern fills with a cistermiser valve.
The siphon has just been replaced so this evidently isnt faulty.
The pipe out of the cistern has been increased to 28mm and has a breather pipe fitted so we cannot see that the issue is due to a flow restriction in the flush pipe.
The only other problem we can think of is that the siphon is airlocked, however it is tight against the ceiling so can't be filled with a bucket to purge this. How fast does the cistern need to fill to clear an air lock?
Has anybody got any thoughts as to other possible causes / solutions?
Cheers
Cheers
