Discuss Understanding CH pressure vessel settings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Valliant regular boiler. Earlier in the year I had several radiators replaced and a pressure vessel fitted in place of the FE tank.
The red pointer is set to 0.75 bar and the black pointer is at about the same point.
My questions are...
Is 0.75 the correct setting?
What should the black pointer be doing both when the system is at rest and running?
Do you have to check the pressure in the vessel and if so what's the process?
It's not that I particularly want to get involved, I have it regularly serviced but I'd like to have a better idea of what's going on.
When cold the black needle will be lower then when the system water is hot. Any pictures? 0.75 is a little low in my opinion. No you don’t charge the vessel yourself.
Thanks for the quick reply. The system has been off for 3 hours or so, but hot water tank is full. Photos attached.
Reply to Understanding CH pressure vessel settings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
I was told by the plumber to keep an eye on the pressure, to ensure it stays above 1.0. The red one is… but the black one is not…. What do the two...
Hello. I am a homeowner and have a Valliant EcoTech 835 (2017). Serviced every year and worked like a treat until about a few months ago when I...
Hi Folks, Where is the place to order a Vaillant filling loop, please? I looked around on the net but can't seem to find it as a kit. I'm not...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
