Discuss Underfloor heating worries in the USA area at PlumbersForums.net
Hi guys,
I'm having some trouble with my builder and the plumber who fitted my underfloor heating. In a nutshell, the plumber has laid Hetta aluminium pipes over c. 40 square metres comprising of two zones. The builder has then laid around 6cm of semi dry aggregate-based fibre screed. He's then added self level compound on top. The only thing left to lay is karndean vinyl floor.
The problems I have identified to date are as follows :-
1. The water pipes were not hot when the screed was laid so I am worried that when they heat and expand, it will crack the screed. (I'm not sure whether this was the plumber or builders responsibility)
2. No insulation was applied around the edging of the screed so I guess there's a risk of cracking either within the screed or the wall plaster (again not sure if this was builder or plumbers responsibility)
3. The self level compound that's been applied was 10 bags of Palace compound mixed with 4 bottles of Febflor latex and 6 part water. (I'm not so worried about this given it's only about 2-3mm in depth).
particularly on the first point, it would be great to know what others recommend I do now? It's been about 3 weeks since the screed was laid so I believe it's too early for my to switch the heating on. I've got to make a call on whether I either :-
a) Crack on with laying the vinyl floor and fitting the kitchen and hope for the best
or
b) dig it all back out and do it again. This will cost c. £500 for the screed and another £1500 for the underfloor heating (presuming the pipes can't be saved).
Would welcome all opinions.
Thanks,
Steve
Don’t need the heating on when you lay the screed but do need the pipes to be full of water and upto spec
this should be ok not the best or correct way but should be fine
normally 2L of water per bag but may differ consult manufacturers instructions
Definitely no heat on whilst screeding. But should have been pressure tested to manufacturers requirement then left at a couple of bar whilst screeding. Slight pressure increase as the concrete goes in and heats up.
Plumbers issue, but builder would have had to let him know when he was screeding.
Edging insulation more to stop heat bleeding into the building structure.
Personally I would warm the floor very gradually in line with the requirements of the screed prior to laying the vinyl flooring. Also the same with the self leveller but that's just me. But I would be annoyed at the new screed needing a self levelling compound.
As said above, it isn't the ideal install but should be OK. My only other concern would be normally there is a foam edging strip placed around the perimeter of the room to absorb the expansion of the screed slab when it is hot, I believe it helps avoid cracking. Not sure how vital it is, may be worth asking a UFH company and see what they say.
As above not ideal the slab will expand and contract and it really should have perimeter insulation , pipework should of been pressure tested and left pressured up whilst screeding , I would warm the slab if possible over a week if you have floor stats this will be simple to do starting a couple of degree increase each day a long slow warming is better than a thermal shock which could possibly cause cracking , I wouldn't be laying any floor coverings until you're confident the floor is sound and the Ufh hold pressure. Kop
The edge strip is to reduce thermal bridging and also allow a modest amount of expansion for the screed. If you are paying £1500 for 35m2 you are being well ripped off! You need to bring the UFH slowly upto temperature or you will thermally shock the new screed resulting is a cracked / damaged floor.
Thanks for the all the replies. After the screed, he's now done two very thin rounds of self level compound in order to get it level. Not ideal at all but I've got to crack on with the job in order to move into the house. Fingers crossed it all works out!
@StephenF - That's interesting that you think I got ripped off. I did get 3 or 4 quotes for the job and all came in at either the same price or higher. What would you expect that kind of size room to cost? (Noted on slowly increasing the temp, I'm not even thinking about switching the heating in for another month or so yet and then will do so in small increments daily)
Op are you sure about the competence of the people on this job?
the cable running to the outlet below and to the left of the boiler isn’t in safe zones and isn’t acceptable, and needs improvement before you plaster
Reply to Underfloor heating worries in the USA area at PlumbersForums.net
Hi all, I wanted to ask a general question about an underfloor heating system our plumber is proposing and if this solution will be sufficient...
We have a Daikin Air Source heat pump feeding our hot water and under-floor 8 port manifold heating system. The Daikin has just had its annual...
Hi all! So yes, Richter level 7 earthquake at least. I need to plan an underfloor heating for a 4x4 expedition/overlanding off-road vehicle, and...
1K
A
A friend wants a radiator moved but has underfloor heating in the kitchen. Do I need to drain the underfloor heating down or is it completely separate
Hi all. We have underfloor heating on a couple of levels in our house. One floor was not heating and I asked advice from a plumber we have used...
