Discuss under pressure swivel tee for gas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pigzy2012
I have 3 of these, brand new are they worth anything, and can i sell them on?? Primofit pe sdr 11 x rs,
looking forward to some advise,
thanks.
luke.
Hi, here is a pic of one of the tee's and also i have three of these not sure if they are to be used in conjunction with the tee's?? photo 1.JPGphoto 2.JPG
Your first pic is part of a tap tee missing the saddle.
Your second pic is a crimped PE ECV gas connection.
No good to anyone as you shouldn't be touching either.
hi I have the same as pic 1 but all in packaging have about 20 could you price them please??
2 bob.
Bin them as they are for use by specialist contractors only and no use to rgi's.
Reply to under pressure swivel tee for gas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
My daughter bought her first home and was hoping to convert to gas but its not available in the area, so thinking a boiler upgrade is the better...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
1K
