- Messages
- 10,034
This has been puzzling me for ages & now today I have had a call about water coming through a ceiling.
Went to it, not knowing anything about the fairly new house & found a Heatline unvented cylinder with water all over the floor below the tundish.
Was actually the relief valve from the red expansion vessel passing water slightly & plumbers had joined the discharge into the unvented d1 pipe. Just dirt in the relief valve, but I notice the tundish leaks water from its open sides. I notice a lot of them do let water out, usually if full volume.
Surely these tundishs are not fit for purpose?
I am G3 qualified & the expansion vessels I checked for air charge, - only fault was relief valve. The D2 pipe is not causing any problem.
