Discuss Tricking water in cistern in the USA area at PlumbersForums.net
My cistern is trickling water and I’ve tried altering the fill level but no change.
any help greatly appreciated.
i do have a video of the issue but can’t upload on here.
Duff rubber diaphram in valve. Depending on type of valve, doew it stop if you lift float up.
Reply to Tricking water in cistern in the USA area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
