Currently reading:
towel rail
Discuss towel rail in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chalky
removed a radiator, fitted a towel rail on a combi system, opened valves and can not get hot water through towel rail, pressure ok return warm but feed cold and water is coming through feed pipe.Rest of radiators ok in house
possible air lock in the pipework, turn off all the other rads in the house except the towel rad to try n force the airlock out.
:cool:
will be a bit messy but.....
shut valves on new towel rad
open top left nut on rad, open right radvalve slowly and this will push air out as water will push from bottom right radvalve to top left nut
repeat other side
job done.
Turn the CH pump off when doing this or you could actually draw more air into the system.
Reply to towel rail in the Plumbing Jobs | The Job-board area at PlumbersForums.net
