M
mike57
Fitted a new Torbeck inlet valve to toilet cistern a couple of days ago. Appeared to work perfectly - no noise or vibration at all when shutting off. But 24 hours later it's producing a loud thump in the pipes (pipe hammer?) every time the valve shuts off.
The valve is fed directly from the mains, whch I had to shut off to install it. It's fitted with the LP restrictor.
I presume this must be a problem with air having got in to the system - I've released some air through the downstairs taps, but can't locate any more.
Any ideas on how to rectify? The key aspect to me is that this was working perfectly for a while.
