I
ian29gte
I have a sealed system, with a plastic top-up bottle. The bottle is connected to the system via plastic tube, and a valve. When the system is pressurised, the valve to the bottle shuts. Should the pressure drop in the system, the valve opens to allow the water in the top-up bottle to drain into the system, keeping it topped up.
The valve was playing up yesterday, so I stripped it and found some thread tape stuck underneath it. It's working fine now, but I have been unable to locate any valve of this type, in case I'm not so lucky in the future.
The valve is brass, has a threaded port for a auto air vent. It has KIWA and Ocean stamped into it. Two local plumbers merchants said they'd never seen anything like it before, and an Internet search has so far proved fruitless.
Any suggestions?
Any suggestions?
