Discuss Toilet Fixture Minimum Flow Pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
relaxjack
Is there any standard or guideline on toilet fixture minimum flow pressure ? eg. WCs, Shower, Sinks, Basins, etc. or its not imprtant as long as the required flowrate is achieved.
There are BS standards to govern flow rates through waste pipe work
Flow rate through fixtures like a w/c,will be incorporated in the design by the manufacturer to meet water usage allowed for a particular function
imho
how about the available flow pressure at the fixture? i've been told 8psi is the general requirement but i've not seen it in any standards or guidelines.
Sorry but I'm not really following your drift
the flow pressure at the basin taps, shower mixers, flush valves, etc.
Think you are not making the distinction between flow rate and out let pressure
Take a look at bs6700
And bs8000 part 13 or 15. One of them is hot and cold water services
Yes, i think im confused here. It all started when i saw a water supply design criteria somewhere i cant recall. Its something like this.
Fixture.......... Flowrate (gpm)........... Flow Pressure (psi)
Shower................ 3.................................. 8
Does it mean that I'll have to provide a pressure of 8psi at the fixture outlet in order to have a flowrate of 3 gpm?
Reply to Toilet Fixture Minimum Flow Pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
