- Messages
- 3,481
Gas fire
The fault was a pilot not staying lit so I ordered a pilot assembly kit. Fitted it okay, but when releasing the button pilot cuts off immediately
i disconnected overheat interrupter on thermostat & bridged with piece of wire, pilot stays lit & main burner works!
I put multimeter on overheat connectors & its closed circuit so now I'm confused! The overheat stat is not faulty it seems, but the pilot will not stay lit with it connected! I'm hoping a new overheat will fix it, but I'm wondering if it will now!?
New thermo gave 20.1 volts on multimeter when hot, the interrupter overheat said something like 0.8 & is closed circuit always.
Any advice appreciated...?
Test wire removed by the way, so all is safe
