Discuss Testing inhibitor in heating system... Should things rust at all? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
NeilFawcett
We had a new boiler put in a few months ago. I'm questioning if the fitter put inhibitor in?
It's a Worcestor boiler which heats up water in our hot water tank and radiators etc etc. From my understanding there's two circuits? Once from the boiler around the radiators and one going up to the hot water tank to heat it?
Do they share the same water?
I've bled some water from a radiator and put it in a jar. I've then got some tap water and put that in another. I've then taken 3-4 screws and bolts in pairs and put one of each in each jar.
Both sets have gone rusty, but the fresh water has got far more rusty.
Should it have gone rusty at all with the water from the radiators?
NOTE: After three months, the water from the radiators is crystal clear!
just so u are aware the tap water isnt the same water that runs around the heating system , the water from the boiler heats the coil in the cyclinder ( like a kettle element ) .If your rad water is clear and the engineer has stated that he has added the inhibitor then alls good .
I know tap water isn't the same as the water in my heating system - I was creating a test set. ie: Regular water rust vs the water in my radiators rust.
So the fact bolts/screws are rusting in the water from my radiators (be it less than in tap water) is OK?
Is the water in the coil (in the hot water tank) the same as the water used around my radiators?
Your test didn't work because there's a large volume of oxygen in the sample. When it's in the system there's relatively little. The inhibitor takes care of the rest.
To answer your question, yes, the water in the tank coil is the same circuit as the water in the radiators.
Aha! And the fact there's less rusting in the radiator water sample must be due to the inhibitor then!?
Thanks...
The inhibitor containers have a sticker on them which you fill in with the date and then put somewhere so it can be seen by anyone who works on the system,usually on the boiler somewhere. I always put them on the drop down door with the cleaner label. Have you checked the boiler for these?
No, nothing like that!
TBH, not very impressed by the plumber involved. Didn't even send off our registration card for the bioler! I phoned Worcestor after three months, only to find out they knew nothing about us!
Hence me wondering if they even bothered with inhibitor with the new install!
If there's no stickers I doubt it's been done,especially if your registration hasn't been completed. Has it been notified with Gas Safe Register?? You should get a certificate through the post.
You can get a kit to test for inhibitor as already said,that would tell you either way. Can you ask the installer?
Reply to Testing inhibitor in heating system... Should things rust at all? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
