Discuss Testing a Type TSR thermostat in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all,
I am looking for some advice to test the correct operation of a TSR thermostat for an immersion water heater. In the past with the old type of thermostats I would test for continuity between the live and neutral (when disconnected). Is this the same procedure for the the Type TSR themostats?
I do not seem to be getting any continuity between the live and neutral even on thermostats that are new out the box.
Any advise is really appreciated
Thank you
You should get a resistance and with it calling and open circuit when it’s tripped / cut
If you are testing the thermostat out of the immersion heater, there is no load between the immersion tabs, so you won't see any continuity between L and N.
Put a link where the immersion would go, and then you'll get a reading! (when it's disconnected from the immersion of course)
Thats great, thank you, I will do that now
If the stat is just out of the box just check for continuity between the two stat terminals and you should get zero ohms.
You just have to be sure which those are - they're not the pair on the front, or the pair on the back! You can see why there
might be confusion!
I think you need to test between the bottom L terminal 'A', and the other side terminal '1' which is on the left when looking at the temp adjustment. Or short the immersion terminals together as I suggested in post #3, and measure between L (A) and N (B).
might be confusion!
Thanks, thats really helpful
Reply to Testing a Type TSR thermostat in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
