Discuss Tap holes or 0 tap holes? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
sulika
Tap holes or 0 tap holes? For a bathtub and also for a sink. what is more quality and what is best value for money?
Manuel Fawlty Towers GIFs - Get the best GIF on GIPHY
No tap hole basin presumably results in wall mounted taps? These are more expensive to fit and often harder to exchange/repair in future.
Bath, you can have a filler spout on a bar valve shower, so arguably cheaper install cost in that element. Or an overflow filler, can be slow to fill, needs a control valve somewhere - more costly to install.
As to quality and value, that has nothing to do with tap holes…
Reply to Tap holes or 0 tap holes? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
