Discuss tap cartridges ( in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mfgs
I seem to keep getting called to kitchen taps which need new cartridges, however they are all difference and I never seem to have the right one on the van. Where do you guys get yours from, as most merchants round here only have one or two different types in stock.
I just change the tap :D
Just read the post about Yorkshire Dave, will have a ganders later
It looks good but no links to buy or any idea of price.
Got a local plumbers merchant who keeps a decent assortment of them, bit pricey though at £8 each (£16 a pair). Also keep one of each of the 2 that Screwfix sell, one of the 2 sizes will fit about 90% of the time.
Failing that, I'll use the tap magician website, they know their onions.
Reply to tap cartridges ( in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
Hi, I can’t get one cartridge to budge when trying to replace in a mixer tap. The hot side cartridge was tight but removed with wrench comfortably, but cold side is so tight Ive burred the nut on the cartridge. Any advice on how else to remove the cartridge without damaging the mixer tap is...
Hello I have a Franke Planar Kitchen tap and it’s got a leak. One drop per minute. I’ve been on YouTube and seen that there are grub screws to remove, first for the handle, then once that is off the square piece between the handle and the tap body to get the cartridge for replacement. I have...
Hi I have a leak on my kitchen tap it is coming out off the bottom of the cold lever. How do I get the lever off? Also would this tap have a cartridge in the cold & hot or will it be just tap has had it & I need to get a new one?
I've got a Glowworm Flexicom 24hx boiler and I'm trying to unplug the installer cartridge in order to wire up the ebus connection inside. From what I've read, it should be possible to do this without opening the boiler, but there is limited access around the boiler and I'm struggling! From the...
