Discuss Taking Out A 28mm Tee to Replace With Connector On Pipe With NO PLAY in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Taking Out A 28mm Tee to Replace With Connector On Pipe With No PLAY
How do i replace a 28mm tee with a connector when the pipes are rigid and fixed on both sides? I.E.. I can't pull the pipe together to get them into a push fit connector.
Do I replace a section with plastic pipe that will bend? Do I put two connectors in and a fresh piece of pipe and just work the new angles? Is there a special fitting for this situation?
Thank you!
You would need 2x slip fittings to allow you to put the pipe in place move slip fitting to correct place then solder them.
You need to cut the tee out and use "slip couplings" but they are only available in copper . Speedfit may make somthing that may do , not sure .
Depending on what type of 28mm solder couplers you have you may be able to file out the little indentation stop and make slip couplers out of the couplers.
I would prefer pushfit fittings as soldering onto old pipe with water in seems problematic.. Imagine steam and poor solder.
If its imperial i.e. 1" copper rather than 28mm pushfit fitting will not seal properly & may require special fittings along with the slip fittings
Reply to Taking Out A 28mm Tee to Replace With Connector On Pipe With NO PLAY in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
