Discuss System drain down..... in the USA area at PlumbersForums.net
I'm going to drain my heating system a bit to replace a three port valve body that's got a stuck spindle. I was going to turn the water off first but I've noticed that the circulation pump before the three port valve seems to have a valve either side of it. Can I shut these off instead of turning the mains off and drain down using lowest radiator? The three port valve is on 1st floor so I wasn't going to drain the ground floor radiators. Will that be ok?
1. You will need to stop the flow some other way. Turning off the pump valves will not stop the flow of water into / out of the three way valve. Also, they have a bad habit off not shutting the water off completely.
2. As King of Pipes has said, unless you have a lot of experience, its better to drain down to below the level of what you are working on. From your post it would seem likely you can drain down only the upper floor(s).
3. If you turn off all the radiator valves you will retain most of the inhibitor in the system, and can probably avoid having to add new. However, for the sake of ÂŁ15 or so you might want to consider a new 1 litre bottle of inhibitor anyway.
4. If you DO turn off all radiator valves, make sure you note how many 1/8th turns are needed to close each lock shield valve. That way you can open the same amount when you have finished, and retain the balance within your system.
Thanks everyone. In the middle of doing this now and I'm struggling to get the valve off the pipework. I've got the nuts off and I've even managed to saw two of the olives off but there's no space on either side of the pipework for me to Jimmy the valve out of its position. Should I loosen the nut on the pipe going into the cylinder coil and see if I can rotate that pipe a bit? I've attached a pic.
You should be able to get the left pipe out even if it means removing a clip then remove it from that’s side, then you can lift the 3 port body up a bit to remove it from the bottom connection and then the last one to remove is the right
also looks like you need a set of new pump valves with new rubber washers
I spotted the clip just before I was about to give up. It was broken anyway so just removed it. Still a pain to try and get a screwdriver in the gap. I've been halted in my tracks, anyway, because I only had one olive in the box with the new valve. I should have checked before I started.
I had a plumber out not so long ago over a slight leak on the pump, you may be able to see where it's leaked on the pic. He said he couldn't loosen the nuts on the pump so put some Fernox leak sealer in the system and it seems to have done the trick. If the nuts are stuck is it a case of replacing that bit of pipe entirely?
:D more likely he didn’t want to drain the system down I would replace them (the whole valve with new rubber washers) if you can manage without filling back up tonight which it sounds like might be the plan ?
Yeah, I'll be leaving it as is tonight and heading out to get the olives in the morning. How much would a new valve set me back?
about ÂŁ15-20 depending on supplier and valves you will need the rubber pump washers as well as your are probably hard go to your local plumbing merchant
you will need a decent set of grips for the big pump nuts
Thanks. Replaced the three port valve now. Had a slight weeping leak on one connection but tightened the nut and smothered in Fernox LSX and it seems to be ok now. I put the LSX on the olive originally but obviously not enough. I'll look into getting new pump valves.
I've noticed on my boiler, in the garage, I've got three copper pipes. I know the two in the top, left corner are the flow and return but not sure what the other one is? It's a Baxi Ecoblue Heat Only.
[automerge]1602270598[/automerge]
[automerge]1602271153[/automerge]
Sorry, I've realised it's the gas pipe. For some reason I was thinking the gas pipe was the plastic one on the bottom but it's the condensate drain.
Reply to System drain down..... in the USA area at PlumbersForums.net
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to sort all of my rads and do some other bits including fitting a filter but I'm stumped on how to drain down due to how the system is put together...
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The issue is quite simple to repair not sure why any one of the 2 plumbers could not fix it. Why am I paying for cover. The auto air vents in part of the...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small 3rd floor flat, I have a radiator in the front room and one in the hall (very close to each other), there is a drainage valve on one of these. My back...
Hi guys. A couple of things. 1 am I better fabricating bends in 14 mm copper for my ch or are 90 degree elbows fine, ref flow, friction ect. 2 my ch boiler, non condensing is playing up, I can get hot water, but when heating is on pipes only get hot for 1st mtre or so? I can hear feel the...
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs covering at leave twice the floor area As per diagram has free flow Up or Down, no way to balance. Works pretty well but last few Rads (in kitchen) are...
