Discuss System boiler recommendations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
I am quoting for a system boiler and UVHWC
not fitted a system boiler for ages, what's good and around 30kw
Is Vaillant stainless or alloy now?
WB CDI classic?
Got a meeting with the ATAG Rep this week to look at theirs again.
Probably going to quote an ideal Vogue for mid range but not sure for top end.
To me, it's not the boiler that's important. It's 100% the pipework.
If you have a system with any 'normal' barrier pipe then the poor thing is doomed regardless cos you can't stop oxygen entering. If however it's all copper and you then fit MLCP UF pipe then almost any will do so long as it fitted well and will last with appropriate deareation etc.
PLEASE dont fit std barrier...
Reply to System boiler recommendations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
