Discuss swithing from central heating to hot water and vice versa in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
michael11
I know that combis have a divertor valve for diverting water to either the central heating or the hotwater but what other components are there for doing the same job.
On combis u pretty much get 2 main setup's.
1. U get boilers with diverter valves/plate heat exchangers
2. U get boilers with a dual pass heat exchanger with a hw flow switch
also as mentioned above u get s&y plan heating for system boilers. There are other variations on all of these but most are uncommon.
you also get pumped heating and gravity hot water still quite common but old fashioned
I will go for
duel pump system,pump for heating and another for hot water
Reply to swithing from central heating to hot water and vice versa in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys, just want to get some advise, basically new vaillant regular boiler has been fitted approx 5 yrs ago, i believe it was back boiler...
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
My first thought when I heard this fault a combi boiler with hot water but no heating. Was a problem with the stat, controls not making the call...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
