Discuss suitable replacement control??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
obseen16
Hi guys,
Came accross a faulty "poly plumb pb pzp" Programmable room stat today, looking at how its wired it appears that its battery powered and only has a switched live connection in the unit. is there a suitable replacement that isnt made by poly pipe? i heard that honeywell did something suitable but cant find anything on their website about it,
Hope one of you guys can help,
Cheers
J
but its a programmable room stat. if it were just a room stat id have replaced with normal room stat but because its a programmable one with no permenant live to power the programmable side (uses 3aa batteries instead) im struggling to find a suitable replacement. even my parts supplier is having trouble finding something suitable :(
I drink Budweiser thank you!
Never understood the need to ferment rice as an adjunct to beer. Especially seeing as budweiser failed so spectacularly in oroducing a palatable beverage.
Somehow though the indians have cracked it with cobra beer. Umpteen times better than bud:sly:
There are hundreds of battery powered Programable room stats, your supplier is carp.
Siemens do one, no 240v relay so it's brilliant unlike the rf rdh ones
Reply to suitable replacement control??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've had a couple of these battery powered thermostats fail and currently looking at finding replacements but I'm fairly sure they are now...
1K
Hi all, My customer has a Honeywell Home ST9500C two-zone programmer. One of these: Honeywell ST9500C 7 Day Two Zone Programmer | Programmers &...
3K
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW...
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT I have three wires in the old...
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed...
2K
