Discuss Stopping condensate waste freezing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My condensate waste has only frozen up once and caused the boiler to switch off, this was on a particularly cold night. I thought of the following way of stopping the boiler switching off in the event of it freezing up again. The pipe drops out of the boiler vertically and then runs horizontally for about 900mm before it goes through the external wall into the drain. If I was to put a tee in the horizontal run with the branch set at 45 degrees and put a bucket under the tee on very cold nights. If the pipe should freeze up then the condensate would still be able to run out through the tee and the boiler shouldn't then switch off. Does anybody see any problems with this idea
If your condensate runs anywhere near a sink or appliance outlet think about plumbing it internally on a permanent basis. It will save you a world of inconvenience as well as remembering to put the bucket out.
No, it runs in the garage, before it pops through the wall to the outside it runs into a waste from the washing machine so the shared washing machine/ condensate waste pipe runs on the outside before dropping into the drain. My thinking on the bucket is that in 10 years it has only frozen up once so I will only have to remember it when it is really really cold.
If it's only frozen once then you may well 'get away with' insulating it 'properly'. So, use a nitrile based insulation like Armaflex (25mm wall thickness) and properly glue ALL joints. Leave NO part uninsulated and remember to compress each length by 10-15% when you fit it so it doesn't pull apart. DO NOT, tape or zip tie it. If you're tempted then I'd not bother even starting. The armaflex site has some great resources for how to do it properly.
Condensate outflow is for building regulations etc. considered as a flue and as such only gsr fitters should work on this area and all components and modifications be approved
Easy way to stop freezing is fit a trace heating kit and lag up the pipework . Kop
There is a trap on the waste before it goes outside so the open tee wouldn't be a problem.
Wrong, the trap must be inside or immediately at boiler in order to be safe, condensate is considered as a flue so thats like saying the internal section of a flue does not matter until it gets outside. Rob Foster aka centralheatking
Put an access plug on the tee?
To be frank, it sounds to me like an idea that can be described as 'stupid, but it works' and I'm quite impressed actually. If you're happy to manage the workaround and empty the bucket, I'm thinking go for it.
My only concern would be that, as the tee is internal, you would get blasts of cold air coming into the house via the tee and possibly drain smells also. Might be possible to put a running trap on the internal horizontal waste run after the tee to prevent these occurrences?
[EDIT - but if Rob Foster's right about the legality of the matter, then it might be better to wait until the gas installers have had their say before making a decision].
can you use this and get your 'engineer' to attache it on next service visit for £10, 20, 30, 1000 etc?
https://www.NoLinkingToThis/p/mcalpine-condensate-pipe-clamp/3101v
If the boiler has no internal trap then this component will not be safe in my opinion as it might vent naughty gas inside the building....which is what all the legislation is about oreventing. centralheatking
Hold on. Is it illegal for him to work on the waste pipe if the boiler does have its own trap? And can you link us to an authoritative website explaining the legislation as this is starting to make me think that this rule means a non Gas-Safe plumber won't be able to work on pretty much any waste pipe if this is the case, given that nearly all waste systems are ultimately interlinked.
I think what it will be down to is pretty much the same as why we don’t encourage people to take covers of boilers some of them form combustion seals some of them don’t the same way that some boilers have traps and some of them don’t. I think to err on the side of caution is a sensible approach
No good to me. I'm a non-gas plumber so if I'm asked to work on an above-ground drainage system that incorporates a condensate pipe I need to know whether I'm legally allowed to or not. If I err on the side of caution and refuse to do so without good reason then I've just lost my business.
Agreed. Nobody's given a straight answer to my #17.
the gas fluing system goes to the first air break after the condensate trap. So if the trap is in the boiler and the outlet drops into a waste pipe, you can do what you like with the waste pipe even replace it with a bucket.
However all the building regs for drainage apply for the discharged water.
Thanks, that's clear enough.
Yes I do see problems with this idea. What boiler do you have?
Reply to Stopping condensate waste freezing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
