Discuss Stop kitchen drain then start drain again in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just a curious question about kitchen drain.
I used flexible hose bent to T-Trap shape under sink. It drains into 2" horizontal PVC into wall where 2" PVC is bent 90 degree to floor below.
Sometimes water doesn;t drain or drains very very slow, then within 10-20 seconds all drains. Next time drains perfectly, no problem. Sometimes I fill the sink, watch water drain perfectly. Then sometimes later, drain stops or slow drain. Then later drains perfectly.
I thought maybe there's blockage somewhere, I snaked about 30 feet, all cleaned, Flexible hose is all cleaned.
So I wondered if shape of T-Trap I bent with flexible hose is too shallow? I tried different shape, still same draining issue.
Any ideas why drain stops then drains perfectly later?
Reply to Stop kitchen drain then start drain again in the Plumbing Jobs | The Job-board area at PlumbersForums.net
