Discuss SS twin-wall flue with condensing oil boiler in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi Forum,
I am about to start the process of removing a wood pellet boiler and replacing it with a Grant Vortex Eco 15-21kW Utility condensing oil boiler.
Flue currently in use is Staovax XQ Stainles twin-wall system, Stovax's manual states "For use with both commercial and domestic high temperature gas, wood, multi-fuel and oil instructions. It is approved to operate with continuous temperatures of up to 450°C" https://www.stovax.com/wp-content/uploads/PM502-XQ-Chimney-System-Issue-6.pdf
Can you please help and confirm whether the current flue can still be used.
Thanks to all in advance
You'd be best talking to Grant UK, although I suspect they'll say no. Flues need to be sized correctly and to manufacturers guidelines. I personally wouldn't save money by reinstalling a second hand flue.
Reply to SS twin-wall flue with condensing oil boiler in the Oil and Solid Fuel Forum area at PlumbersForums.net
Grant Vortex 50/90 condensing oil boiler where the air tube spigot over the fan is not connected to the existing flue, should this be closed off...
  • Locked
Hi all, I am new here and a capable plumbing DIYr. I have just purchased a Fire Bird Silver Boiler House model to replace my old and now leaking...
4K
Hi, I'm still getting used to oil after converting from wood pellets. I'm fairly happy with it's operation, but slightly adjusting temperatures...
3K
    • Love
Recent install Firebird 26kw Condensing boiler. Space heat only. Installed as replacement boiler in well insulated 80s renovated home. (Silver...
15K
Hi - I have a Myson Velaire oil boiler which was installed in 1988. The boiler has been very reliable only needing a good service and rarely a...
2K
