Discuss Soil stack tee in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tommy1712
just went to sort a dripping toilet what should have been a simple job just replace a straight pan connector with a offset. Simple right?????
first the flush broke
then the elbow falls out the tee and won't seat in properly ffsssssssssss
surely the elbow should be tighter then just pushed in
It's sometimes the simple ones that turn into a nightmare . Can u fit a new elbow ?
Dunno I think it's seated better than before going back tomorrow with a new flush, it's a mates house so it's not so bad and he ain't moved in yet so just left the water off, was getting the hump with it lol
I don't usually touch soil stacks due to what they are covered in! Only put a pan connector in. This 45 elbow just fell out tho! And the coupleing pipe just pulled out and the back nut to the flush was stupid tight yet the flush still span with no real effort
Probably some numpty has removed the rubber ??
Worth checking if you can see ?
Its always the jobs for friends and family that cause all the problems, and to top it off you do it for fee.
Reply to Soil stack tee in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Sonya K
