As I understand it a balancing issue is where individual rads take lions share of hotter feed , normally at the start of the loop , leaving other rads further downstream to be fed with cooler water. Surely if this was the issue at least 1 rad would be excessively hot and this is not the case.If all was working well once, it is now almost certainly a balancing issue.
