Discuss Shower temperatures all over the place in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I was having issues with my shower temperatures being stuck too hot - it wouldn't ever get cold.
It's fed from a combi boiler and has a hand shower head as well as a fixed head on the tiles.
I managed to educate myself on how to configure the temperature and found my happy medium after much twisting and turning. I managed to take a comfortable shower under it and thought that was the end of it.
Wife tells me it's too cold the next day and to be fair it's nowhere near the temperature I had set it up at. Much deliberation later, I gambled on the fact the thermostatic cartridge might be knackered. I've replaced this and I'm getting a similar issue.
I set to a hot max this afternoon but I could still reach cold on the other end of the spectrum. Job done I thought. I've gone to take a shower tonight and it's far far too hot and I couldn't achieve cold. Took the control apart again and I can get a decent max temperature for a minute or so and then it gets hotter and hotter without changing the controls.
Just looking for any last piece of advice before calling a plumber out -
I've replaced the cartridge (and as far as I believe there is no right or wrong orientation to install it)
The water temperature from the boiler is set at 60c max and we don't seem to have temperature issues elsewhere in the house
Boiler is a vokera compact 29a
Any ideas?
Did it come with fitting instructions ? Are you sure it's in correctly any indication on the cartridge cold on the right hot on the left as you look at the shower Valve ?
Reply to Shower temperatures all over the place in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
Hello. My mixer shower (non-electric) recently started running luke warm. I know this can happen at this time of year over winter but I've been in...
Hello! Im Martyn Im new here and have joined for some advice on a couple of things. Ive got an issue with a Mira mixer shower that has...
Morning all, I have a Worcester Bosch 8000 life 40kw boiler on system with 7 radiators and the boiler is located in the loft of a 1907 end of...
WB 4000 installed a few months back, just balanced the 7 rads - managed to get around 15 degrees delta across most rads. Not quite the 20 degrees...
