Discuss Shower fixings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Leoki
I have the hot and cold water pipes coming through a tiled wall ready for me to connect my new thermostatic mixer valve. The tiler left me a very nice circular hole for each tail and when i have offered up the collar that goes over the end of the tail of the pipework that sits between the wall and the shower itself i find i have cocked up with my measurements. The collar that sits on the wall is off centre so i can see the top of the hole in the tile. Can anyone suggest of a place where i could buy a chrome finish, effect washer that could go behind the colar so that it hides the mistake that i have made. I need about 2inch outside diameter and a centre diameter big enough to go over a 3/4 threaded tail.
You won't find anything like you describe. Chop out the offending tile and do the job properly. Anything else will be a bodge up!
Not sure if I've missed something but many plumbing merchants and sheds have chrome cowels that are around 2" in diameter.
if all else fails you could try a metal work specialist who could make a plate for you and chrome it, expensive but its your choice
Like said remove tile and re do correctly,if you are worried about extra cost,mark new tile correctly were you want holes and ring tiler up and take tile to him were he is working,he can re-drill and cost will not be so much,sure you can stick a couple of tiles back on if you are fitting shower
Or get your self down the local chaves shop,sure you will be able to pick up a few silver or gold round pendants to cover hole,if you are lucky they may have some with a bull bog or staffs face on,that you can fit on the top and hang your soap off :)
Make a cardboard template for the tile and where you want the holes in it before you actually drill the tile!
Reply to Shower fixings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
hello all, happy new year! i hope i have posted this in the right section i have a shower bar mixer. the shower runs luke warm. a quick google...
2K
I have just replaced the old bathroom basin mono mixer taps, 2 tap heads, standard compression valve type, to a modern mono mixer single lever...
3K
I'm in the process of refurbishing my bathroom. I'll be replacing the existing bath with a walk in shower. Will be installing a thermostatic...
