Discuss Shower Cold, plumbers clueless in the Plumbing Jobs | The Job-board area at PlumbersForums.net
AWK
shower cold unless hot sink or bath tap turned on for a few seconds.
shower then remains hot for about a minute then goes cold.
Original shower Mira minilite evs, replaced with an Aqalissa bar type....
still same problem. Using a megaflow unvented system with mains cold direct to shower, spoke to a plumber on phone... he aint got a clue..HELP.
Then something has changed have you removed the shower and run the water is it a noticeably different flow from H&C??
Are you getting ok hot at all other outlets
Your mains SHOULD come to a combi block next to the unvented cylinder and be balanced so you get equal h & c everywhere. Is your kitchen tap a mixer?
been working fine for 20 yrs, problem started about 3 weeks ago.
I’m not picking, but that would have been helpful from the start, moving on... what has changed plumbing wise in the last 3 weeks? Or have you had any work carried out?
yes kitchen tap is a mixer. nb before fitting new shower I purged the lines and the cold had a lot more pressure than the hot.
Could be the kitchen tap. This will be fed from the main and not balanced from the unvented, except the hot. Theoretically it could be the same, but a pressure reducing valve may have been used? Also when was the shower replaced?
Try isolating the kitchen tap altogether if isolation valves are fitted, then try running the shower.
Ok don’t take our suggestion. It could be that the cold is forcing its way back up the pipe in the tap body toward the cylinder. It may not be that but you have to find the possible failure points
fail too see how the kitchen tap would affect it as it would not be used when showering, I fitted the new shower a few days ago.
It doesn’t matter if it’s being used, I once came across a kitchen tap install, whereby the kitchen tap wasn’t being used, yet the tank in the loft was overflowing because it was backfilling into the tank, which was caused by a failure in the tap. Usually on unbalanced supplies.
Is your shower cold feed from upstream or downstream of the combination valve that Riley mentions above ? (Downstream would seem best to me)
**video removed we do not offer any advice on working on unvented cylinders even via you tube as you need to be G3 qualified to do so***
How old is it ?
How can a plumber diagnose over the phone?
Answer he cannot especially if not unvented trsined. Get a G3 trained engineer in to have a look if it hasn’t been fixed already.
Go to the top of the class CBW1982 AND RILEY, mixer tap in bathroom sink causing problem... isolate one side and water out of both. just had a hot shower YIPPEE. Thanks guys.
You do realise that @townfanjon suggested this an hour after you posted your question, and you dismissed him straight away saying your other taps were fine. Try listening to the experts next time your given good free advice.
Reply to Shower Cold, plumbers clueless in the Plumbing Jobs | The Job-board area at PlumbersForums.net
