Discuss seeking experienced advise on an intermittent fault on ideal logic combi? in the Gas Engineers Forum area at PlumbersForums.net
Mines a c30 plus.
Kept having peculiar things happening to it.
It was under warranty only 2 years old.
I installed.
So I got ideal out turns out the thermisters where dropping in and out between swichnover.
To fast to notice had to be plugged in to show when it dropped out . It was that fast enough to confuse the boiler.
[automerge]1574504952[/automerge]
New thermisters been ok since
Might help
not to expensive to change either
[automerge]1574505112[/automerge]
Mine also played up when running the boys bath.
Cheers for the advice. My issue only occurs when there is a demand for HW when the boiler is off? Do you reckon thermistors would be the first change?
I was thinking if it was the spark generator I'd be getting a lock out on CH as well but I never do. I was thinking gas valve or fan as these are modulating on HW demand but I'm not sure. Inlet pressure is 19.5.
Is that at max rate?
Does it dip at all on initial fire up?
Cleaning the brass Venturi
Washing through the heat exchanger
Checking spark gap
Cleaning the condense trap and rubber hose are part of Ideals ‘full service’
Reply to seeking experienced advise on an intermittent fault on ideal logic combi? in the Gas Engineers Forum area at PlumbersForums.net
E
Have an Ideal Logic + 18 with intermittent fault. When on demand the display constantly changes from O to C but burner doesn’t start. Can fix by...
Ideal logic heat 18. Uncoded intermittent fault near end of days use only. Burner reignites every 15 seconds on and off, but no fault code...
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
F
Hi, We have a new Ideal Logic Combi 30. A radiator today came off the wall and developed a leak. Plumber came and fixed (but didn't). At that...
FrankMcg
F
Hi, As per the thread title, I have an Ideal Logic Combi 30 and I am having a problem with the pump, which keeps activating without any DHW/DCH...
