Discuss securing a toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
coolwaterpaul
Hi, can anyone tell me the best way to secure a toilet onto conctete securely, i have tried different ways, but the toilet becomes loose after you sit on it a few times......
Size and type of screw or bolt, types of raw plug if any....
Any info would be handy.
Cheers....
Google Image Result for http://www.NoLinkingToThis/sfd/i/cat/43/p1969243_l.jpg
I've used resin mortar to good effect in the past. Drill the fixing holes oversize, inject mortar into the holes and run a bead under the base of the pan. Then bed the pan down and push a couple of brass screws into the fixing holes. An up to date version of the old standard of bedding it on mortar.
Mike
[DLMURL="http://www.ukplumbersforums.co.uk/redirector.php?url=http%3A%2F%2Fimages.google.co.uk%2Fimgres%3Fimgurl%3Dhttp%3A%2F%2Fwww.NoLinkingToThis%2Fsfd%2Fi%2Fcat%2F43%2Fp1969243_l.jpg%26imgrefurl%3Dhttp%3A%2F%2Fwww.NoLinkingToThis%2Fprods%2F43370%2FFixings%2FFurniture-Fixings%2FPan-Bidet-Fixing-Kit%26usg%3D__2err8ohTlr1b0VntZy68dy1-3_w%3D%26h%3D200%26w%3D200%26sz%3D7%26hl%3Den%26start%3D17%26um%3D1%26tbnid%3DpVt3SVlMl7wd4M%3A%26tbnh%3D104%26tbnw%3D104%26prev%3D%2Fimages%253Fq%253Dtoilet%252Bpan%252Bfixing%252Bkit%2526um%253D1%2526hl%253Den%2526sa%253DG"]Google Image Result for http://www.NoLinkingToThis/sfd/i/cat/43/p1969243_l.jpg[/DLMURL]
Excellent, just what i need, cheers Sonray......
make sure the pan isn't wobbling about on an uneven floor, use shims around the base to stop it moving about. If its sitting "steady" you've got a much better chance of securing it.
Reply to securing a toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
