Discuss Sanicompact not flushing properly or filling bowl with water in the USA area at PlumbersForums.net
Hi, I've got a sanicompact downstairs which has been working fine for 6 years. In the last day or so I've noticed that the toilet isn't flushing properly and subsequently not filling the bowl back up with enough water. The water that does come in comes in very slowly and it makes a sort of hissing noise. Any ideas please?
Update, I found instructions and I think the problem is a clogged solenoid valve filter. Does anyone know how to access and clean it? Is it something a non plumber could tackle?
Seem to remember the filter is part of the valve not a seperate item. Are the holes around the rim clear?
I haven't attempted to get into it yet, haven't worked that bit out yet!!
Disconnect power at wall and remove cables, disconnect water, drain bowl, remove pan to floor screws and flip pan upside down. Check filter. Remove pump/motor box, remove end cover if you have too.
Opps slight change, you dont remove end cover, you split the central covers to get to the valve.
Reply to Sanicompact not flushing properly or filling bowl with water in the USA area at PlumbersForums.net
