Discuss Rusting solar expansion vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kev the gas
Hi all,
I popped into see a job today with a problematic solar system.
12 evacuated tubes
Twin coil cylinder in the loft, along with pump station and expansion vessel.
System not circulating but pump running, I checked the expansion vessel and saw it was badly corroded and leaking Goooo!!
Pressure gauge reading 2 bar but I think it is stuck, the sight glass for flow rate was mucky.
Obviously the leak has caused air in the system which is only 3 years old, the expansion vessel has already been replaced because it was leaking.
I presume the system was not cleaned out before final commissioning and the flux is now corroding the system ??
from my course @ Worcester 2 years ago I'm sure they said a there is a minimum head for Evacuated Tubes??
Can anyone confirm?? or dismiss my theory:2guns:
The customer is 85 years old and a little fed up after spending £7000 3 years ago.
The system was installed by So Solar of Southampton
Kev
Soldered joints are a no no so system shouldn't need flushing?
Heat at damage maybe? Or has the wrong type of expansion vessel been fitted or in the wrong orientation?
Thank you for replying Nostrum,
Exactly why I mentioned the soldered joints, I have only fitted 3 systems and have used the flexible coils and compression where I had to.
The expansion vessel is fitted at an angle to the roof joists using straps !!
The expansion vessel is correct for use in Solar installations. ( it says so on the sticker!)
Thx Tamz,
you just woke up my sleepy brain !
Above is a pic of my last install, East/West split with Cooling vessels, from the roof down to the garage not a single joint using the coils, then using compression only at the pump stations.
I think I got a bit too involved with their bad luck story to think properly, I have just had a message from them nd they want it all removed and a new boiler installed.
Kev.
Reply to Rusting solar expansion vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
