Discuss Rothenburger Eco Pipe freezer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Plum Bob 66
Hi There
Although I usually extole the the Rothenburger Eco Pipe freezer on Monday it let me down badly and I was majorly brassed off as I couldn't get it to go below -5 degrees for love nor money so in went the bungs and job done.
As this is no cheap piece of kit I was starting to get a bit worried about repair cost ect as the unit is out off warranty. Set the freezer up at home and had one more go, no joy so decided to ring Rothenburger uk. A very helpful lady answered the phone and diagnosed the problem straight away and talked me through the fixing process. Joy of joys it was down to -23 like feacal matter of a long protrusion !!
So heres how its done at no cost to you !
  1. With freezer turned off lift up the front electric dispaly panel, dead easy.
  2. locate big silver screw on black box (cant miss it)
  3. Undo screw and fill reservoir to the top with tap water.
  4. With screw off , turn on unit and set up clamps on 2 test pipe with appropriate reducers.
  5. Set to desired pipe size, press the * button an then the on button
  6. Temp should start to drop and at the same time watch for air bubbles rising from the black tank.
  7. Once the air bubbles have stopped rising and machine has reached -23 and starts beeping, replace silver screw firmly.
  8. Let out large sigh of relief !
Apparently air getting in the glycol mix had been a problem on the early models had been a common complaint. Incidentally the problem has been rectified in the newer models
For any body that's interested Rothenburger Uk can be contacted on 01536310300
Hope this information is useful to somebody
Happy Freezing Bob ;)
This is the exact reason I hated the first ever model of this. The fz400. Very temperamental
Glad to hear
May I suggest you monitor the glycol level if you keep on topping up.
Glad to hear
That would be wise !
Got a price of plumbase for 1 today 500 inc vat anyone had a better deal when they brought theirs
Reply to Rothenburger Eco Pipe freezer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dear All, I hope you might be able to point me in the right direction with an issue I have with a 3 year old Greenstar 30i boiler, last serviced...
Hi. Our Vaillant Eco Tec Pro 28 (13 Years Old) stopped working two days ago. The boiler was trying to fire up but the start up sequence never got...
3K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
N
We've got a great new UK Persimmon home with dry wall linings. We're planning on putting screws in the wall in the following locations: 1 Above an...
9K
Hi Guys, Got a issue with a kitchen sink. I Installed a new island kitchen sink not long ago and they have been having problems with the...
1K
