Good morning, and thanks for the positive words above!
We’d like to give some reassurance over the materials used and the testing we perform to ensure the strength of SafeClamp, if we may?
The composite material used in the main beam is glass fibre reinforced nylon. The design has been optimized using 3D CAD stress analysis software. We have tested this beam against a conventional steel cross beam on our destruct test rig, and whilst the steel beam collapsed at around 500Kg load, the SafeClamp’s composite beam took around 1300Kg loaded in the same configuration.
Again, thanks for the compliments; hope this information is helpful.
Kevin - Rhino Products Limited
