Discuss Replacing Fordham Flush Panel toilet fill valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone replaced a Fordham Flush Panel toilet fill valve with modern one with integral overflow mechnism?
Don’t forget a syphon IS an internal overflow mechanism, as long as you get the correct height one for your cistern there is no need for an external overflow.
Thanks for your comment but the issue is the current valve requires an external overflow pipe while modern ones have integral overflow mechanism that does not require an external overflow pipe that improves the situation.
???? A lower syphon fitted to a cistern will not require any overflow pipe if the syphon internal of highest part is well below level of any toilet handle or existing overflow.
You can then simply just plug off or seal up the original overflow once you have the new lower syphon installed
Reply to Replacing Fordham Flush Panel toilet fill valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days it's increased whilst cold...is this a regular problem.
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
