Discuss Replacement Grohe mono block in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How can i buy an exact replacement as i cannot see how to open the barrel to the hot ceramic disc to replace that?
Grohe
About 8 years old.
Chris
Doh.
I pulled, pushed then I twisted the handles and looks like I have broken the cold tap as it now spins right round and still the blessed thing is closed tight.
Time to see if I can fit a new tap.
The problem is that I have very little access and wanted to fix what I had.
Reply to Replacement Grohe mono block in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
PSxxxxxx
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
