Discuss Replace radiator valve but nut stuck in the DIY Plumbing Forum area at PlumbersForums.net
Replacing bathroom towel radiator, while I‘m at it was going to change the valves for new ones, however this bottom nut is completely stuck…. Any advice for getting it off? Have tried using grips to hold still while using spanner to undo, have tried WD40, it just won’t budge 😬
Reply to Replace radiator valve but nut stuck in the DIY Plumbing Forum area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
PSxxxxxx
