Discuss Repiping Central Heating System Advice in the DIY Plumbing Forum area at PlumbersForums.net
I am repiping my whole house and changing from combi boiler to a 30kW system boiler & 250Ltr or 300Ltr unvented indirect hw tank.
Can somebody give advice on my rough plans/sketches for repiping my radiators using 22mm & 15mm. I have only shown the flow line as the return line will just be a replica. I have attached blank drawings if anybody could shown me a better way.
Is my boiler and hw tank size sufficient for this?
Thanks in advance.
Copper or plastic ?
1 15mm
2 22mm
3 28mm
Are the last 2 pictures on zone two joined eg up stairs and down stairs or are they individually run / zone 3 etc ?
Can I ask explanation for why 28mm pipe used?
Because of part L regs all homes must to suitable going forward for an ashp and a max flow of 55 used to calculate rads and pipework
Would use 28mm on the upstairs until it splits off then go off the drawing
Thanks for the information mate, ill look into this.
I was hoping to avoid 28mm cooper because of the price haha. If i need to use it then I will just have to bite the bullet.
Reply to Repiping Central Heating System Advice in the DIY Plumbing Forum area at PlumbersForums.net
I need to extend my central heating from my newly built extension in to the old part of my house. I need to feed 3 rads in separate bedrooms on...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Hi, I'm after some advice for a current system which I'm looking to replumb. Our house has had various extensions of heating system with newbuild...
Sandy Rivers
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
Hello, I have just installed a vented McDonald 250L thermal store, it is for multi fuel but currently just connected to a standard oil boiler in...
