Discuss Remove reducing olives in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Cut the pipe below the reducing set
Is that with a hacksaw or pipe cutter?
Hacksaw will get you closer so you won’t loose / shorten the pipe as much as a slice / cutter
Reply to Remove reducing olives in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Do any of you guys use this type of reducer? It doesn’t have an olive and the bottom part of the brass compresses onto the pipe by the looks of...
I’ve just swapped these new valves over live. Didn’t realise how bad the old nuts looked until finished the job. Would it be hard taking these...
Hi guys, These sleeves cover 10mm PVC central heating pipes (see picture and ignore tape measure) and I believe this is what makes it possible...
I'm a kitchen fitter first and foremost, so occasionally encounter old pipes of varying sizes. From past experience I know how easy it is to...
Hi All, I have replaced my existing Shaw and Mason chrome set with the Shaw and Mason forward bowl spindles/ Handles. I have kept the same tap or...
PRJSyd
