- Messages
- 3
anyone tell me how to remove the flush pipe to replace a leaking washer on a gerberit enclosed flush system please?
Discuss removal of flush pipe on a 2008 gerbrit 109.720.00.1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thank's for that, have a happy and prosperous New YearPlastic snap ring needs to be removed then rubber seal can be removed.
Do you mean flush plate or pipe ,to take off the plate to gain access to flush valve just lift the plate up slightly and pull forwards to open ,to change flush pipe you need to remove the toilet .
Thanks for your quote YD I had other things to do and have just got round to picking up the thread so ,if you don't mind I will do the thanking myself. Cheers Andrew I did have to get the cistern out and it is the flush pipe I needed to remove to stop a leak, thanks for your help.I'll say, "Thanks for asking Andrew" on behalf of the rude OP
Most times I would remove the cistern not the pan myself as they are either grounted into tiles or silconed down. Each to their own though Andrew.Thanks for your quote YD I had other things to do and have just got round to picking up the thread so ,if you don't mind I will do the thanking myself. Cheers Andrew I did have to get the cistern out and it is the flush pipe I needed to remove to stop a leak, thanks for your help.
Reply to removal of flush pipe on a 2008 gerbrit 109.720.00.1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
